Old 03-13-2006, 09:09 PM
nestorpr nestorpr is offline
Default Re: I/O prep for anti foul paint - How to ?
You'll have to prime the unit with a tin based primer and anti-fouling paint so the aluminum won't suffer from electrolysis. If you go to the Mercruiser or Volvo website, or to any of the anti-fouling paint websites, you can download specific instructions on each product since many of them require very specific methods to follow. Thi is the safest way to do it.
As to how to get into the hard to reach areas, first you have to make sure everything is VERY clean and oil free. Then you'll have to trim the outdrive up and use differenet sized brushes to get into every nook and cranny. The only other way would be to remove the outdrive and do it in sections but then you'll need to install new gaskets and such and is quite complicated.
Good luck!
Boatless again!
