Old 03-14-2006, 01:00 PM
Bay Runner Bay Runner is offline
Default Re: Trim tabs + paint ????????
PeterB, Stainless can be drilled with a sharp metal bit! The trick is Slow drill between 400 and 600 rpm and don't use any oil or lube, you will be supprised at how easy stainless will cut. Also if ya'll are using up anodes that quickly there must be an auful lot of electricity leaking into the water from somewhere (your boat or a neighboring boat).
