Re: Cetol Marine Gloss
I like the gloss look. Apply not two but three coats sanding in between with 320-400 grit sandpaper.
If you can take the pieces off and lay them flat, apply thick coats of cetol, the finish will look awesome. If you can and must apply on vertical surfaces, make sure you apply thin coats.
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
