Old 04-07-2006, 06:57 PM
CaptScottNC CaptScottNC is offline
Default Another tank floor job (photos) Battery Box ??s
Well I'm started up my first major project on this boat after just installing my trim tabs. I've pulled the tank which was corroded and had a dime sized hole on the starboard side that was being covered by the foam keeping the fuel from spilling. I did noticed some gas smell in the bilge so good timing on pulling the tank although I suspect it has been seeping fuel for some time before I even purchased it but probably not known to the owners before. So I'm getting a new tank coming.... OUCH! Now I knew the floor was already soggy from reaching under the tank and started pulling that up. The floor had a ton of flex when walking on it and I'll attach a string of photos because we all like photos. I decided once I was down there and could get around in there to go ahead and move the batteries into the console storage area. So I'm replacing the battery cables and switch with all new and shrink wrapping all connections so I hope to get many many years of trouble free use out of them. Here's the photos of the floor coming out. You can see there wasn't much in the way of good wood left anywhere.
OK now here is my battery box question. I noticed the "knee" that comes from the transom to the side of the fishbox and then connects somewhat to the stringer was loose. I peeled back the glass that was holding the floor in and that pulled up some of the glass on that knee revealing what you see here.
So my question is the soft wood under the battery box is not of "structural importance" is it? The wood is not soft on the sides but it's detached where it would attach to the floor and it doesn't appear to be ever have been well attached to where it connects to the stringer. Just curious what feedback you guys have on the wood under the battery box. Thanks for the help.
Scott
Atlantic Beach, NC
1977 Sea Craft 23SF
250hp Suzie 4-stroke
