Old 04-10-2006, 05:45 PM
Default Re: Specs on an 84 20SF
Hull weight: 2100 lbs dry
Fuel: 70 gal
Max HP: 235
deadrise at transom: 20*
yet all of the spec sheets i have seen on this site list the weight at 1,600 lbs fuel capacity at 47 gal, max hp at 175 and the deadrise at transom at 16*. can anyone confirm what I was quoted as being correct or incorrect? Again, this is for a 1984 SF20. Thanks
Look at the '82 Seacraft Brochure here:
http://classicseacraft.com/brochures...ure/index.html
I have an '83 20' SF. I believe Seacraft Industries made the 82, 83, 84 20' hulls. To be sure, you can search the archives for the mfgr timeline. If the 84 SF is similar to my '83 hull, the overall length is 20'-4", 8" longer than the Potter 20 SF. Some other particulars:
Fuel capacity 70 gal, confirmed
Deadrise at transom 17°, actual measurement on my hull
Dry weight 1700lbs, from the brochure
Max HP 175, from the brochure.
I don't have a CG rating plaque in mine, so if you can confirm that 235 hp rating for the 84 SF 20, I'd be interested to hear about it.
Blue Heron Boat Works
