Old 04-18-2006, 08:05 PM
hermco hermco is offline
Default Re: wood stringer options
The strength is in the glass you put over the core. I would not use wood. It will rot and absorb water,is needless weight and does not give you any strength. You should reuse the original box stringers,remove the foam and add more glass over them or get a 4 lb density sheet foam and fabricate your new stringers from that.
