Old 05-03-2006, 10:14 AM
Default Re: Yamaha 150's Water Pumps?
Ear muffs suck. Be careful with them. You have to force water to the impeller for the ear muffs to work. Normally the impeller sits below the water level when the boat is in the water. You are probably right about the lack of pressure. If the engines have sat for a long time then there will be no water in the lower unit. Coming back from a fishing trip and then using the earmuffs while the lower unit is still "primed" with water gets better results with the ear muffs. I just had the same thing happen to me this weekend. Engine would not pee with the ear muffs. Put it in the water at the dock and it started peeing as soon as I fired it up.
Strick
