Re: I maybe a SC owner again, a little help
Update: The floor fix in front of the console looks good in the
sun, the top and floor were re gelcoated and a pretty good job, at least as good or better than I could have done, sides are have 1 scratch and are in remarkable condition. There is 1 hole in the gunnel- 2" that looks like an antenna was there before the T Top so I'll be back for advice the guy some gel coat left. Jeeezzz thats a big console but with the T Top can't change it. The motor will be the kicker if it checks out were in, should have the water pump done today, the transom looks original and has 2 small gel coat cracks at bolts holes and 1 bolt inside shows some pull thorugh on the inside, so the motor has to come off. I am confident there was some higher power at work for the boat to show 5/9 2 blocks away, 48 hrs after the 1st comment from the cruise director about upgrading boats, maybe there is some Angel hanging out in S Tampa that used to have one LOL
I will now have 3 boats until the other 2 go
