Old 05-19-2006, 12:36 AM
Default Re: NEED HELP WITH FLOOR DRAIN REPAIR!
scott, my boat is a 20 SF. i did another little test tonite. i put a plug in the bottom of the brass tube and poured water in the drain past the top almost level with the deck. opened the rear hatch and watched. could slowly see water running into the bilge from the bottom. previous owner had already tried to repair this by putting what looks like thickened epoxy down there.. looks sloppy. so i think i will remove the old tubes, let the wood or fiberglass (not sure what they are mounted in) dry and fill with epoxy and redrill for new tubes. i hope this is as easy as u guys make it sound.
