Old 05-25-2006, 02:09 AM
warthog5 warthog5 is offline
Default Re: Transom extension on a 74' 20' seacraft
So far I have used epoxy fairing compound to join all the cuts together that this fella made to pull the boat apart,
It might just be your wording here? Did you glass the part' back together, or just use fairing compound?
Also, is ACQ or pressure treated plywood the same thing as marine grade plywood?
I think you ment ACX? ACX and most preasure treated plywood is Pine. It's heavier in weight than Fir.
The standard for Marine plywood is BC Fire Marine. However there are other's that are more expensive.
There's to many void's in ACX and standard preasure treated plywood is to wet and inhibit's the bond of resign and glass.
