Thread: My first
Old 06-20-2006, 06:26 PM
RODMAN RODMAN is offline
Default Re: My first
Chance, I would check with a test light or volt meter,you said you can hear a clicking at the slave,check voltage as someone trys to start at both sides slave from eng.ground and battery ground.You should have power on that slave on bat. side and when you att. to start (hear the click) power should on starter side.(rember use eng. ground and batt. ground just to make sure you have a good ground)Power on batt. side,,att. to start (click) check starter side,no power bad slave.Power on both sides check term. on starter and power at the starter.If you have power at starter when att. to start you have a bad starter. Hope this will help.
