Thread: My first
Old 06-20-2006, 06:41 PM
Default Re: My first
Thanks Rod man, however i know both the slave and starter are good as another slave was put in today (that makes 3 just to make sure) and the starter i tested before i installed it 5 days ago and she worked fine. I was going to do more tests but the rain came. If i can bring myself to look at it again i will go back latter tonight. Thanks for any help. Also i put in 2 new batteries with 12.7 volts each. I heard that 12v is only at 25% and that will burn out the slave if used at 25%. Still no change however, same damn noise. It has to be either a ground that i can't see or a bad wire. everything else is brand new. If it wasen't for bad luck i would have no luck at all. What is even making things worse is the fact that i toped her off the other day and i hear that if you don't use the new fuel within 15 days it starts to loose octane (or something like that) So after i get this fixed i will probably have issues with the fuel system. I may be a little pessimistic at this point. Sorry
