Thread: My first
Old 06-20-2006, 09:52 PM
Default Re: My first
I did some tests, however some of them i can't do becuase i don't know where to put the positive and negeative to see if the thing is working. this is what i got: Battery no load (pos to neg on battery) 12.7V, battery with load (same setup except with key turned) 12.5V. Some one here says that if it dosen't drop a full volt that the starting circuit is bad. What does that mean? also checked the slave selonoid (i think) by going positive battery terminal to positive side of slave with load and then without load. got 0V no load and the same with load. I put the positive side of meter on stater selonoid positve cable and the neg on starter case and got 12.7V Now the way this is wired goes something like this: The positve battery cable is coming from battery directly to the starter selonoid, then some wires go from there to the wiring harness and some go to the slave selonoid and some go ?? Does this seem right. It seems to me that the pos battery cable would go to the slave first and then back to the other selonoid then to the starter. why would it go from starter selonoid to slave back to starter?? I don't get it. What does this tell you guys if anything. Thanks for everything
