  #172
Old 07-06-2006, 03:30 PM
Fishjack Fishjack is offline
Default Re: Splashed!!!!!!!
Bobby - When you raise or lower the engines on the bracket how do you ensure another good seal? Remove all the bolts, re-coat and replace? Looks like we will be going in opposite directions - yours UP mine DOWN.
According to my flow scan I am at 2.4-2.5 Avg MPG at 34-35 MPH. With your twin Suzies you will be doing great to get 3 MPG..
FWIW - I Called Don at D&D to verify the height of the motor - he said that with my single D&D OB bracket the cavitation plate should be 3 1/2 inches above the keel.
I took a long straight edge and measured it - my motor is currently at 4 1/2 inches. Dropping it one hole should make it about perfect - we'll see.
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
