Old 07-14-2006, 10:32 AM
Default Re: Limber Me Timbers
Ha Fish On
Here are a few suggestions for ya.
1. Seacrafts have a variable dead rise hull design so water Will accumulate at the bottom of the boat in front of you CC area. You can look at the bilge on the trailer on flat ground and think you don’t have any water in the bilge but you just simple did not see it. If you put the boat on the ramp with the plug out all that water will run out. Maybe water is accumulating in the bilge after it rains and is running forward in a pool up there???
2. Check all the through hull fittings like live well pump, intake line valves and possible low bilge pump exit holes, all hoses, etc every screw and hole in the bottom and sides of boat for possible entry. Some times a hose or hose clamp is the problem. As Capt Chuck said could be water in the live well leaking out or over the top.
Good luck
FellowShip
_______________________________________________
My motto: Just for the Grins
