Old 07-25-2006, 07:50 PM
Default Re: Phase one of my could be major overhaul
Hmmmm, they are some pretty toes huh,strick! glad to hear you are watching my rebuild attempt. I can handle a lot of the mechanical stuff but my glass work leaves much to be desired, so i am studing you guys works of art and will give them my best shot....but i can only hold out so long before i must fish!!!! . I pulled the foam out of the port side tank today and it is completely dry. go figure. I got my rudder stuffing box broke loose today also finally which ive been dickin around with a while. Im thinkin instead of awlgrip on the deck I might just use interdeck epoxy cause it really aint going to do nothing but get beat up again???? (gaff hooks, bats, nets, rod butts etc ). Im just not sure its worth the extra cost for the deck. Cap will be a different story. Mama is being unbelievably non-combatent too, i wonder whats up wit dat??? - Im going to use 1/2" solid silicone rubber strips to lay in the hull lengthwise under the tanks and use gary hills method of 3 or 4 coats of epoxy primer on the tanks and use just a minimum amount of foam to keep the tanks from shifting. Ill shoot some pix and keep posting them as i put her back together.-
craig
