Re: 1971 20 SF Transom project
I am using polyester laminating resins.
I mean inside skin of the transom...sorry about the confusion. Thanks
Greene, are you the same Greene some the cm site?
If so, I used your transom job as sort of a template because raybo had alot of input in it.
If you remember, How much resin did you use?
Hows your transom holding up anyways???
Do you have any advice on what NOT to do? Thanks
-Andrew
