Old 08-06-2006, 04:25 PM
Default Re: Stringer problems!
I opened the floor up on my 72 GW and I have termites, bad! I can already see replacing all the stringers out to 8' from the transom! I am removing the inboard so i can pprobably beef up everything to handle what i plan on powering this boat with. Whats everyones opinion on what to use to rebuild stringers with? I want to get pics of everything before i go any further, so I'll get some stuff posted soon.
Marine Ply sandwiched together with epoxy to the correct thickness of the existing stringers. Use a cabosil/epoxy mix to glue the stringer in place after you have them cut to shape. West systems book shows how to repair parts of existing stringers. Laminate it with a few alternating layers of 1808 or mat/18oz roving. US Composites sells a nice thin laminating epoxy resin and it's fairly inexpensive. Otherwise I like the system III 2:1 epoxy. Short nap rollers are excellent for wetting out mat and not making a mess of the fibers. Good Luck . . . It will be years before you're boating again. I still think you should find a better boat worthy of your money and time.
