Re: 74 Seacraft Tsunami
Good to hear from someone local. I dive, skin and scuba out of the Hatch and Cedar Key everyonce and a while. Mostly the grounds and deeper now though. I know a ton of SPUC's however, I am a member of Team Headhunter a Spearboard Club.
I'm not too sure what you a are saying about the stern. I moved the fuel 8 inches forward and added a large fishbox up front to offset the weight. The tank racks as you know, can slide forward or aft. I figured sliding 6 tanks on each side 6" forward or Aft (by design) will significantly change how the boat sits in the water. I also have a slider that goes between the battery boxes.
Are you thinking I'm too stern heavy? I'd certainly like to know. Are you running a similar set up.
I've put a ton of thought into setting this thing up.
Love to hear from some owners with similar set ups.
Thanks again for the help!, Jason
