Old 08-27-2006, 08:52 PM
RODMAN RODMAN is offline
Default Re: MARINE INBOARD VS. REGULAR SMALL BLOCK
Also a hot rod engine has to be torn down and refresh every so often. They use thin rings to prevent breakage,but wear out faster but can handle the revs,less drag on the cylinder wall= More HP.And you would have to use a higher grade of gas.My choice would be a stock engine.Will give you more hours and the best bang for your buck.
