Old 08-30-2006, 02:01 PM
wendell wendell is offline
Default Re: Inboard running cold
Chance,
The theromstat should be installed crown (pyramid) up with the flat button side down. If the motor is actually running cold (bellow 180) you're going to GREATLY acelarate the wear on your motor. Cylinder walls will wear from poor lubrication and increased piston/wall clearance. Bearings and journals will also be the worse for wear because the oil will not be functioning optimally. With in reason it's actually better to run too hot that too cold. A motor that spends a few years at 220 will be in better shape than one at 170.
Any ways...
Are you still mored in plymouth? I've got a 23'hydrosport skiff in the harbor. If possible, I'd like to check out your boat. I'm going through a 23 inboard with my buddy kmodi in my shop in carver and would love to pick your brain. Great looking boat, good luck.
