When ever I used epoxy it was with a vacuum to pull the epoxy in.I am not sure but you may have to cut your own matt because the epoxy will not wet the matt ,I believe the matt is bonded with starch. Aha..
What I have done is use what I call horse blanket and cut it up to make your own matt to do your corners.Good Luck
