Old 09-22-2006, 12:37 PM
warthog5 warthog5 is offline
Default Re: Question for Hermco, and other \"glass masters\"
2ntow Let me make a suggestion before you paint that bracket. I did this to mine. Same bracket with a "V" bottom.
Where the gusset's are that weld into the top of the platform There are 3 of them.
Drill a 1/4in hole thru them in the tight corner. This will not effect the strength at all. It will act like a Limber hole.
When you wash the boat or just sitting in the rain, water will drain and not collect dirt and soap when you wash the boat there. On the center gusset, you will not be able to get the drill motor in the right spot. Just drill part way thru each side at a slight angle. Run a chamfer bit on each side of the hole's after they are drilled.
I hate water that will not drain and collect's dirt. This work's Very well.
