Old 10-18-2006, 12:05 PM
GradySailfish GradySailfish is offline
Default Re: livewell on 20 ' 1978 MA
I have a 78 MA, and it has the same configuration as the drawings, although I originally had a 70 gallon tank that took up the space up front. I bet your live well config was after market desing/modification.
I repalced the 70 gal with a 55 gallon tank, which freed up something like 24 inches. I was going to push the tank all the way foward and convert the area behind the tank into a well (i.e. make a bulkhead, seal and plum), then I changed my mind and plan to fill the void with foam to increase floatation in case "something" bad happens. I moved the tank as far foward as the coffin permits as I want to keep her from being ass heavy!
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
