Old 10-22-2006, 10:49 AM
Default Re: Through transom scuppers
I was hoping it would be just a matter of making new ones ala bonefish. I guess I better rethink that. What's the best method of pulling out the brass tubes in the floor drains...??....looks like I could grind off the flange and just push them out.
Here a couple of shots I snapped by holding a camera under the floor. Look like the floor has a built up area that mates to a built up area on the hull. I'm wondering if the white stuff is the adhesive they used to put the liner in??
You can see the seam pretty clearly....I assume if the brass tube leaks then it would leak into the hull through the seam??? You can see the shape of the drain channel along the back at the top of the photos....
Portside
Starboard side
