  #31
Old 11-21-2006, 03:24 PM
spareparts spareparts is offline
Default Re: WOT speed on a '83 20' SF w/200
my book shows the WMV 3 carbs as the XR6( 150 hp) and the WMV5 as the 200,
WMV3 XR6 jets
Main .074
Idle air cylinder 12346 .044
cylinder 5 .048
Vent air .082
WMV5 200
main jet cyl 1,2 .082
cyl 3456 .080
idle jet cyl 1,2 .052
cyl 346 .028
vent jet .096
it gets pretty confusing when you start changing around carbs and jets, see if you can find a complete set of 200 carbs, confirm the jet sizes and put them on
timing
pick up 2-9
total on XR6 19 @ wot 19
total on 200 carb @wot 20
total on promax without spark advance box 25
not much difference between the motors with the spark advance box, but with out on the promax 25, keep in mind the jet sizes, they are rolling a lot more fuel in on that one, and on the XRI, the injection goes rich at wot throttle position. Don't push it unless you're getting fuel to it. As far as the oil injection goes, unless a new crank gear was installed, don't chance it, especially if you decide to twist it up.
Go back to the hull running wet, try a jackplate, and if you are getting a good enough hole shot, start tappering the hook out of the hull, use a straight edge and DA.
