Old 11-27-2006, 05:09 PM
bigeasy1 bigeasy1 is offline
Default Re: Finally,my new 1974 Tsunami.
Thanks for the comments guys,maybe i can donate the bike to the Smithsonian haha,.I thought about cleaning up the lures,but tossed them instead.I did find some good stuff though, like a nice dial tourque wrench,four downrigger weights,at least twenty 1lb drop weights,and a bunch of Blacks releases.
I have a question regarding the floor drains.I know that they drain thru the bottom of the hull,but what material connects the floor drain to the outlet? Is it a plastic or metal tube?,i haven't had a chance to look.
Do they ever rupture,or leak into the bilge?,and could i put scuppers out the transom if i replace it?
I also noticed that there were plugs in the floor drains,does that much water come onto the deck?.I will be using it to troll the great lakes and am wondering if i used a washdown pump while trolling at 2-3mph if it would drain ok.
I currently have a 22'Trophy with transom scuppers,which work pretty good unless i have too much weight in the stern.Are the Seacraft floor drains better or worse at draining water?
Thanks again
John R.
All this,just for a boat ride
