Old 11-30-2006, 11:11 AM
John R John R is offline
Default Re: Rest in Peace - A Sad, Sad Night
Peter - Sorry to hear this news. Hopefully you can get her out, cleaned and turned around with relatively little work.
What Strick means is that the brass tubes that line your rear thru-floor scuppers can potentially rot away and allow water to enter between the hull and floor, below your plugs, and fill the hull that way. They should have a putty/glass/wood surround that the brass tubes go through but they can break, and even shift and help compromise the tubes. There were a few threads here in the past on that possible problem.
Good luck
Surf and Boat fishing for
Striped Bass
