Re: Please post your wiring pictures.......
The design of that block and the way it fastens you can't solder end's to the wires. I just stripped double the length I needed and folded that area in half and twisted it to form a larger gauge wire.
On the madian voyage I had lost imfo to the VHF. I knew right where to look and found a ground wire wasn't tightened enough and came loose. [my falt, they are tiny screw's]
A 5min fix on the water.
