Old 12-18-2006, 08:23 PM
Default Re: Mercury 225 No battery Tilt
John, If I recall correctly,
Three wires on the TNT at back of motor from side switch
Connect jumper cables to
the red and blue wires
Blue "sky" up
Green Down
Red -Hot
All you need is a good battery or jump start battery box
to make it happen.
Good luck .
See ya Ken
Or loosen the bleed screw located on the starboard side
engine mount, through the access hole. It is just below
and in between the mounting bolts. Then lift motor and retighten bleed plug screw.
