Thread: Redoing Transom
Old 12-26-2006, 12:40 AM
warthog5 warthog5 is offline
Default Re: Redoing Transom
You are correct IF you can get the bag to seal. It's pretty easy to do with a even surface around what your bagging. The problem comes when you throw the stringers sticking up in the mix. It can still be done, but there is a bunch more area that need's to be sealed.
Your under a time element thing here to get the vacuum on it before the resign start's to kick.
Excess resign running down in the bottom can be a real pain to get the bag sealed. Duct tape will not stick, again leading to more time spent to get it sealed.
NOTE: The word bag here is used weither were talking about a actual bag or a sealed plastic sheet.
