Thread: Stringer help
Old 01-09-2007, 02:05 AM
Default Re: Stringer help
That one stringer isn't going to be cheap to fix (probably $500+ in materials). I'm gonna guess it'll take about 10 cubic feet of foam, 10 yards of 1808 (depending on the width), a case of ice cold beer and 5 gallons of resin to fix. If you pick 4lb density foam . . . you can sand it a little better than 2lb.
If you suspect the other stringer is wet inside drill some holes near the base of the stringer and dry out the foam. Then patch up the holes (if you want too)
