Old 01-16-2007, 09:34 PM
Default Re: Bracket tub shape opinions
You're on there SC.......I think the beer to epoxy ratio is 1/1...
Some quick calc's....with a 28 inch setback and a width of 52 inches that'll be 1456 square inches...or 10.1 square feet. So for every inch above the sloped bottom it sinks in the water, that's 0.84 cubic feet...which is 50lbs of flotation. The V bottom is about 8 inches down from the corner so that should be equivalent to 4 inches for the area
which would be 200lbs of water. So I should have 400-500 lbs of flotation...... The old water line on the transom was about 18 inches up from the keel which would give me 14 inches or so of bracket in the water. I think I need more beer to think about this any more...
