Re: 1000 watt in hull transducer
Just a question here as i can't tell from these pictures...Unless you install a fairing block on the underside of the hull to keep the transducer shooting straight down won't it not show what is directly below the boat?
I made a highspeed fairing block for mine and cut it to match the deadrise of the hull where i placed it. I then used the opposite side of that block on the inside of the hull to keep everything point straight down.
