Old 02-25-2007, 12:47 PM
Default Re: 89 23cc fuel tank
Thats a tough one. You already have removed the cc and t-top and have the tank exposed so you are 1/3 of the way done. I don't like foam around tanks you cant see what in the heck is going on. Ask yourself this question. Are you the type of person that can sleep well at night wondering if you should have pulled it? If so then Leave it. If not then pull it. I toss and turn a lot so I'd have to pull if it were me. No doubt that after 18 years there is at least some maintence that needs to be done such as fixing that corroded fitting and possibly coating the tank with a protective agent. If there is going to be any fuel or water in the foam it will be toward the bottom of the foam.
