Old 03-15-2007, 01:43 PM
spareparts spareparts is offline
Default Re: repost...Awlgrip/Gelcoat
lots of sanding, when you think you're thru, you're only about 1/4 of the way there. AwlGrip primer is ike sanding concrete. Pick up the application guide and read thru it. Most importantly, make sure you have a proper place and time to do it, the last spray job I did, I didn't get it on the boat in time, the paint didn't cure completely before the dew settled on it and flattened the slickest coat of paint I've ever sprayed.
