Old 03-18-2007, 07:06 PM
jerryjc jerryjc is offline
Default Re: What is that plug?
If the previous owner has the plug on the outside of the hull there is a pretty good chance that the brass thru hull is already cracked and would be leaking into the bilge without the plug on the outside. Normally the plug would be on the inside to keep water in the well, you should check that out carefully if it is cracked and you remove the outside plug you could sink the boat. Good Luck.
