Old 05-01-2007, 05:42 PM
Default Re: Possible Leaking Scuppers???????????
There could be a few different reasons you got water in the bilge.
1. Because SeaCrafts are variable dead rise hulls you could have had water in the bilge that ran up front and know really knew it. “If” you looked into the bilge before you got on the road and splashed the boat.
2. Water could be seeping in from the front drain are “If” your boat has one. Would be on the bow starboard side of the boat.
3. Water could be coming in from any of your through hull fittings usually the ones which are underwater.
4. Plus as been stated Could be coming in from the Scuppers. When I re did my boat those scuppers run through a small block of wood under the deck and above the bottom of the hull. Mine were rotten and I replaced them and then re did my scuppers through the bottom of the hull again. But now since I get bored every once in a while I decided to re do my scuppers through the transom with In Line scuppers. Bought the stuff but haven’t install yet.
FellowShip
My motto: Just for the Grins
