Old 05-05-2007, 01:03 PM
osprey osprey is offline
Default Re: Possible Leaking Scuppers???????????
Make sure that you have limber holes in you stringers aft. My 89 23cc had none. I'd start with a dry bilge and end up with a few gallons of water by the end of the day. Water gets trapped outside of the stringers and goes foward around them when you use the boat. When I drilled my stringers to epoxy pvc pipe in, at least 10gal of water came pouring out. Not good for the stern. I actually could see water seeping through the stringers.
