To foam the stringers it is better to have full access to them. You need to drill several holes along the length of the stringer and pour the foam in. The foam kicks off fast so pouring the foam into one access hole wont allow the foam to creep all the way the length of the stringer before it kicks off. Also the foam will buckle fiberglass if there is no escape route once it fills the stringer.
