Old 06-01-2007, 01:51 AM
warthog5 warthog5 is offline
Default Re: Help with transom mount transducer placement
Mount in so that the bottom of the 'ducer is 1/8" below the hull, with a slight angle forward.
Yep. A 1/8in below at the transom and a 1/4in below at the aft end of the ducer. [Slight tilt looking forward]
I should also be on the STB side. Every instruction sheet that comes with a ducer tells you that.
