Re: motor,cavatition plates and not being correct
Actually the Cav plate should be as high as it will run without Cavatating. Your being on a bracket means the water comes up off the hull to the props because of the setback. Check when your running and see where they ride, you might want to go higher, you just don't want the extra drag in the water, did this answer it??
