You will have to remove the screws that hold down the CC and then remove the screws that hold the deck down. If you elevate the CC approx 4” after removing the screws you should be able to slide it out the back after you remove the leaning post as well. You could prop up the CC with 4”x 4” blocks on both sides.
FellowShip
__________________________________________________ ________
Just for the Grins
