Old 07-06-2007, 09:32 PM
red20 red20 is offline
Default Re: 84' 20SF WET BOAT PROBLEM.....
i had both bats under my console on my '84? also had factory stainless steel flappers on the scuppers. they worked pretty good keeping the water out. they were heavy enough to stay closed while at rest but the force of the water when under way was strong enough to drain out. I did make a slight mod to change the angle on the flappers. I fab'd up a shim to put a better angle on the flapper to make sure they were shut when not under way.
