  #31
Old 08-08-2007, 01:48 AM
Default Re: Here We Go Again
Ken- you are right about the pin holes.... very irritating..... you fill one and five more show up for the funeral. Are you talking about the gantry crane at harbor freight for $560? That sounds about right I got it on sale last month for $539. Very well built it seems.
Bobby- I'll check on the aluminum tomorrow. I kinda doubt it though. What I did with the primer was shoot a light coat on first so I could see the areas that needed to sanded more or built up more. After the fairing and sanding I shot another heavier coat on and then sanded and faired a little more. The outside of the boat is getting close to being straight. what I will probably do is put two more heavy coats on it next before I paint. I have a question for you as I was going to e-mail you but I'll bring it up now. I was reading the awlgrip manual and they talk about the last coat of primer and painting over it without sanding it first. I cant remember what I did last time but I was under the impression that the primer should be sanded with 220 prior to paint? yes I did thin it and you are right in that it really don't need to be thinned much if any at all. I've been having some difficulty with my two compressors. The little one I have cant keep up the with the spray gun so it drops pressure while spraying. I have cords strung out from the house to the shop and the voltage drop wont allow me to run the bigger compressor. I'll have to figure something out before I try to paint.
Rhett- I got the wire covered but we need to go fishing soon before all the albacore head up north!
tito- welcome to the site and thanks. Read back thru the project for the answer as to the squares. The topic was discussed already. As for the bracket a properly built fiberglass bracket will be as strong or stronger then the aluminum. There are no welds to break.
