Thread: Prop Issues
Old 08-28-2007, 12:15 AM
Default Re: Prop Issues
Will send you a pm tomorrow with a spreadsheet of rpm/mph/gph/mpg from 4 different props I've tested. That 150 E-Tec is really about 165! I've seen almost 50 mph on my Seafari; don't know how much the bracket is worth but I'd think you should get mid 40's with a light load. Make sure motor is not mounted too low; should be able to run with cavitation plate about an inch above bottom if running a cupped prop.
