Old 09-03-2007, 11:19 PM
Default Re: Restoring Gelcoat
Here are some before and after shots after using Polyglow on hatch, cabin top & sides. It's MUCH easier than waxing, and the gloss is better than I expected! Just apply the liquid to the chamois in the kit and wipe the surface. Wait a minute or so for it to dry, and then apply another coat. I put on a total of 6 coats. Can put on a couple more coats after 6-12 months. PowerBoat Reports says it'll last a year in the S. Fla. sun, so we'll see.
The kit contains a very strong cleaner and a white 3M scrubbing pad that will take off dirt & oxidation (and the Polyglow coating!) so need to start at top and work down to avoid spots from the cleaner. Surface needs to be really clean because whatever is on it will be there for a year or more after coating! The milky-looking stuff is evidently a clear urethane coating, similar to clear coat used on cars these days. Although I've waxed the hull several times, I have never waxed the cabin top or hatch in the 32+ years I've owned this boat, since folks occasionally walk on it with wet feet and I was concerned about slips & falls. No one has slipped in all that time, and as you'd expect the gelcoat is fairly porous and just about worn thru, so time to either protect it or paint it, and I'd rather USE the boat than spend time painting it!
Have only done the hatch in this shot, so you can see how dull the gel coat is.
Here I've done the whole cabin top. I'm amazed at the difference. Seems to work just like clearcoat on a car. The color also now matches unfaded gel coat on instrument panel.
Decided to go ahead and do the entire deck including non-skid area. It now has some gloss but non-skid is still effective.
Here's a shot of cockpit coaming and pedestal seat after coating. These areas have been kept waxed over the years. Gloss is very good in these areas. Had not coated the side deck in this shot and that was a mistake; should have done it at same time as coaming because I got some spots on coaming when I cleaned the side deck! It also helps to have a tack rag handy to pick up anything that gets on surface between coats.
Need to redo bootstripe next so I can coat the hull. Think I will try Signature paint, Chuck. The Interlux Interpoly I used about 1990 hasn't held up too well. Denny
