Old 09-08-2007, 12:53 AM
abl1111 abl1111 is offline
Default Re: Installing rod holder in Bow gunnels. help!!!
Home Depot < $35.
Worked like a charm w/ a few holes I needed to make in my transom. It guarantees that you drill a perpendicular hole.
When I installed a full transom swim platform, I drilled oversized holes for the bracket bolts. Filled the oversized holes w/ epoxy and then drilled through them for the smaller bolts that would actually hold the platform brackets in place ( replace one transom and you realize how important it is to not let water seep into wood ! )
