Old 09-27-2007, 07:21 PM
EBEACH EBEACH is offline
Default Re: How much GelCoat??
Don,
Thanks for the info. Too bad I just bought the Duratec. I was aware of the patch booster from Ferro. I’m using Ferro brand gel coat, but the working time as indicated on their website says 5 minutes with the patch booster.
I used 2% MEKP as directed by most manufactures. I’ll go down to 1.5%
What are you using to spray with and tip size? What are your working temps and are you cooling the material prior to use, or is it at room temp?
Thanks, Jim
