  #398
Old 10-30-2007, 10:48 PM
Default Re: Here We Go Again
Richard- Thanks for the tip on the trim reservoir. I will level it out. The module is for the fancy trim indicator switch. This is the first set of Bennets I've owned so I'm not all that familiar with them. The module may be a new addition. Do you have the same trim indicator switch ?
GFS- Thanks. If you have room to lift up the consel and set it on blocks then you may be able to accomplish it without disconnecting everything. I see were mentioned in a previous thred that you had a roofing accident. I used to work hot tar and gravel for a couple years out of high school. Tuff work. I got burned on one of my hands real bad and it was not long after that when I decided to get into something else.
